Manfred73's avatar
Dec 19, 2020
Very slow internet speeds R8000
Since a week or 2 I get very slow internet speeds when using the R8000. Sometimes the entire connection drops. I have a 250 Mbps (downstream) and 25 Mbps (upstream) internet connection. I already h...
  • Manfred73's avatar
    Apr 22, 2021
    Well, in my case I think it was not Armor: when I switched to a new wifi 6 Asus router, the problem was still there. Eventually it turned out to be some application running on my Synology that was draining the internet connection. After tuning the settings of that application, it worked fine again. Strange thing was that it used to work fine before with the previous settings, so I didn't suspect any application causing this.
