WBrook
Mar 02, 2022Aspirant
Virgin M600 -> Netgear Nighthawk slow wifi
Just upgraded from M350 to M600 broadband with Virgin. Virgin Hub 4 is set to modem mode. Cat 6E cables used. Speeds are topping out sub 300 when connecting to the R8000 via wire and wifi. Sp...
WBrook
Just to add...
Firmware Version
V1.0.4.76_10.1.82
qos, traffic monitoring, access control, and parental controls are disabled
Mar 02, 2022Guru - Experienced User
Even though access control, traffic monitoring, parental controls, and qos are turned off, were they ever enabled?
If so, factory reset the router and reinstall it. Those services disable ctf (needed to hit gigabit speeds). And I've seen it not get re-enabled even after those services were disabled.
So if you have, try a factory reset.
- WBrookMar 03, 2022AspirantThanks for the tip. I did enable and disable some of the options in the hope that this might kick it into action. The router restarted each time. This made quite a difference to the speed (up to about 500) but I’ll still give the factory reset a try too. Thanks!
- FURRYe38Mar 03, 2022Guru - Experienced User
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router- plemansMar 03, 2022Guru - Experienced User
Backups are always good to have but if you're having issues, a backup can sometimes have the old/bad setting causing the issues.
so worth it to have but if your having an issue after a firmware upgrade/downgrade, I'd avoid them.
