YusufB
Aug 17, 2021Tutor
Vlan allows WiFi connection but no internet
This is driving me nuts me so im hoping someone can help me..I used to be a Network guy but 15 years off the tools and i forgot much of what i need to know to sort this.
Switch 1 Ground Floor: Netgear GS418TPP POE 16 port switch (Vlan 1 left untouched)
Port 1-2 LAG to switch 2 - Vlan 30 ports configured as T
Port 3&4 POE to Unifi Pro AP's - Vlan 30 ports configured as T
Switch 2 Second Floor: Netgear GS724v4 24 port switch (Vlan 1 left untouched)
Port 1-2 LAG to switch 1 - Vlan 30 ports configured as T
Port 13 to Unifi Pro AP (POE Injector) - Vlan 30 port configured as T
Port 7 to Ubiquity USG Pro4 Internet router - Vlan 30 port configured as T
I have set them all to T as they are either trunk ports or to a Wifi Access point.
Everything works on the native network with 20 odd wired clients and another WiFi corporate network.
There are 3 Unifi Pro AP's each on a seperate floors. Ground and second floor cannot connect or get an IP through Vlan 30 SSID "Skyhigh" but we can connect to Skyhigh on the third floor (from a third netgear switch also running a LAG on ports 1-2 no worries)
The issue i have is only the Vlan 30 clients cannot connect on the ground (switch 1) or second floor (switch 2)
Attached pic is the config from Switch 1 - cant seem to post a second pic???
1 Reply
might get more help in the managed switches forum.
Forum for Fully Managed Switches L2/L3/L4 IPv4 & IPv6 (netgear.com)
