Chrispybacon
Jul 24, 2021Tutor
VLAN Configuration
I have a GS308T that I am trying to configure and I am having much difficulty. I need one physical port to connect to my router as the trunk port for all traffic to the Internet. I also need three ...
michaelkenward
Jul 25, 2021Guru - Experienced User
As we are talking about a switch here, I would have thought that setting up a VPN happens on your router.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but switches don't have much on common with routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- ChrispybaconJul 25, 2021Tutor
Thank you Michael, I appreciate your help. I thought I was posting in the "Switches" area.
I will repost my question in the correct area as you have suggested..
