Chrispybacon
Jul 24, 2021Tutor
VLAN Configuration
I have a GS308T that I am trying to configure and I am having much difficulty. I need one physical port to connect to my router as the trunk port for all traffic to the Internet. I also need three ...
schumaku
Jul 25, 2021Guru - Experienced User
Chrispybacon wrote:
I also need three VLANS configured s follows: ports 2 thru 6 as VLAN 10, port 7 as VLAN 20, and port 8 as VLAN 30. For security purposes I want VLAN 20 isolated from the other ports, and port 30 also isolated from all other VLANs. All VLANs need access to port 1 for internet access.
This hasn't much to do with a true 802.1q VLANs where each VLAN makes up it's own network. What you try to achieve here is a so-called asymmetric VLAN config. Netgear does not have this documented (to my knowledge).
Convinced a moderator will also move this thread to the Smart Plus And Smart Pro Managed Switches Forum btw..
