Icebear8's avatar
Icebear8
Vlan internet wont save settings when applied
i am trying to setup my router to replace my centurylink modem/router, but everytime i setup the Vlan on the internet port and change it to 201 it will save but as soon as i hit apply my router will reboot and then it will default back to normal (which is 10)  and the check mark never lights up for enabled. any way around this? i am on the latest firmware it says V1.0.3.48 (even though the netgear website says the latest is 1.0.0.130
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Icebear8 wrote:
    i am trying to setup my router to replace my centurylink modem/router....
    The R7500v2 is a router. It cannot replace all of the features of a modem/router.
    So what are we talking about here? What are you using as a  modem?
    No idea where you are looking. There has never been a 1.0.0.130 in the 15 or so firmware kits available for the R7500v2.
