fo0barbaz
Dec 31, 2021Tutor
VLAN setup
Nighthawk RAX48 (AX5200) I know about VLANs and configured them on cisco routers. I want to separate wifi clients on both bands into to their own vlan and only allow them to send and receive traf...
microchip8
Dec 31, 2021Master
VLANs are not supported by stock firmware except for IPTV/ISP config.
- fo0barbazDec 31, 2021Tutor
Can you recommend a custom firmware for AX5200 (RAX48) that supports VLANs?
Thanks
- microchip8Dec 31, 2021Master
There is none at the moment. Your router is too new and it'll take 3rd party firmwares a couple of years to catch up. I know FreshTomato supports VLANs as I've used them in the past, but it doesn't support your model yet.
