fo0barbaz
Dec 31, 2021Tutor
VLAN setup
Nighthawk RAX48 (AX5200) I know about VLANs and configured them on cisco routers. I want to separate wifi clients on both bands into to their own vlan and only allow them to send and receive traf...
fo0barbaz
Dec 31, 2021Tutor
Can you recommend a custom firmware for AX5200 (RAX48) that supports VLANs?
Thanks
microchip8
Dec 31, 2021Master
There is none at the moment. Your router is too new and it'll take 3rd party firmwares a couple of years to catch up. I know FreshTomato supports VLANs as I've used them in the past, but it doesn't support your model yet.
