AnnieOzi
Aug 06, 2018Follower
Voice port
We contacted our ISP to ask them about getting rid of our old fixed home phone and using VOIP. They said we needed a voice port on our modem, or we had to buy a VOIP handset.
I can’t see a voic...
- Aug 06, 2018
Voice Ports are 'normal' phone cable ports.
The modems that support voice have eMTA support. You can't 'add' that, it has to be built-in, so you'd need to replace the existing unit. Your ISP should be able to supply that for you? They'd just swap out your existing modem.
As for you installing your own modem/router/eMTA, it might not be easy or even possible. I have Spectrum with VIOP. They have a LIST of approved modems they'd allow to be attached to the system. NONE at eMTA units, and very few DOCSIS 3.1's either (needed for higher speeds).
So I'd check with the ISP and see what they suggest for units with eMTA they will even allow to be used.
IrvSp
Aug 06, 2018Master
