ajmich
Jun 11, 2020Aspirant
VPN 101: Does the router's VPN feature make NordVPN software redundant?
Nighthawk AC2100 (R7200) VPN confusion -- I use NordVPN v5.5.4 software for anonymity. This router is new to me. Does the router's VPN feature take the place of NordVPN? IE, is Nord redundant no...
- Jun 18, 2020
Yes, it would if you wanted to use Open VPN over NordVpn on the router.
DarrenM
ajmich
Jun 17, 2020Aspirant
Thanks. To clarify, does the Netgear VPN feature essentially remove the need for NordVPN? I simply no longer need Nord software because the router serves the same purpose?
DarrenM
Jun 18, 2020Sr. NETGEAR Moderator
DarrenM
