c7c4c7's avatar
c7c4c7
VPN Certificate errors
I have a nighthawk r7000p and am trying to implement a VPN, the Firmware Version is V1.3.1.44_10.1.23 .  I've gotten past several easy error but am having problems authenticating using certificates....
  • c7c4c7's avatar
    Nov 14, 2018
    There was an extra line in the config file
    I had an extra line in the config file
    remote-cert-tls server
    Removed it and the connection was established
