sijicl
Jul 15, 2017Aspirant
VPN connection drops every several minutes on my AC1750
Model version: R6700V2 Firmware:V 1.0.0.34 My VPN client is Cisco AnyConnect Secure Mobility Client on Mac, I need it to work remotely every day, but the VPN connection drops every several minutes, ...
- May 17, 2018
Upgrade to latest firmware yesterday, no drops since. I consider that "fixed" as often as the VPN would hang or drop. While I was in the Admin panels I also changed QoS for my work computer to Highest. I doubt that had any effect, I believe the firmware upgrade fixed the problem.
DrewL
Sep 21, 2017Aspirant
I have had the same problem for 3 weeks in a row and it makes working remotely virtually impossible. My VPN connection drops out between 1 and 15 times an hour.
I've updated firmware and restored to factory default two times. I won't be buying a netgear router ever again after this experience. Not worth the pain.
