sijicl
Jul 15, 2017Aspirant
VPN connection drops every several minutes on my AC1750
Model version: R6700V2 Firmware:V 1.0.0.34 My VPN client is Cisco AnyConnect Secure Mobility Client on Mac, I need it to work remotely every day, but the VPN connection drops every several minutes, ...
- May 17, 2018
Upgrade to latest firmware yesterday, no drops since. I consider that "fixed" as often as the VPN would hang or drop. While I was in the Admin panels I also changed QoS for my work computer to Highest. I doubt that had any effect, I believe the firmware upgrade fixed the problem.
cl226
Jul 26, 2017Aspirant
Did you find a solution to your problem? I am having the same problem and it is very disruptive to my work day. I know it must be the router because I can connect wirelessly with other routers with no problems. Thanks for any help you can offer.
sijicl
Oct 20, 2017Aspirant
Why you mark this issue as resolved? The problem is not resolved at all either by resetting factory mode or update to latest firmware, please reopen this issue as it bothers so many customers
