sijicl
Jul 15, 2017Aspirant
VPN connection drops every several minutes on my AC1750
Model version: R6700V2 Firmware:V 1.0.0.34 My VPN client is Cisco AnyConnect Secure Mobility Client on Mac, I need it to work remotely every day, but the VPN connection drops every several minutes, ...
- May 17, 2018
Upgrade to latest firmware yesterday, no drops since. I consider that "fixed" as often as the VPN would hang or drop. While I was in the Admin panels I also changed QoS for my work computer to Highest. I doubt that had any effect, I believe the firmware upgrade fixed the problem.
cheesesteak
Feb 15, 2018Initiate
Add me to the list of people with this issue. I upgraded to this router about a month ago and experience at least ten drops per day on my Cisco vpn. I initially thought it might be a wifi issue since my company issued laptop is five or six years old and doesn't even see the 5 GHz channel. I switched to a wired connection but still get the same frequency of vpn drops. Somebody earlier in the thread suggested changing QoS settings but offered no details. Any help would be appreciated. This router is significantly faster than my old Netgear router but the old router never dropped the vpn and I need the vpn to always be up for work.
cheesesteak
Feb 19, 2018Initiate
Of course, the day after my previous post, I noticed that there was a new firmware update available. Firmware update V1.2.0.16_1.0.1 fixed this issue for me. 4+ days since installing it and not a single vpn drop.
- WillC777Apr 08, 2018Aspirant
I read your post and updated the firmware. I tested the vpn connection and it stopped dropping me so far. Before the firmware update I was watching the VPN reconnecting about every 2 to 4 minutes.
- zethuzApr 13, 2018Aspirant
I have had the exact same problem!! I use the same router and same VPN, and for me the issue started after I updated the firmware.Disheartening to see that this issue still stands unresolved.
- StantraywickMay 17, 2018Aspirant
- dpchristieMay 23, 2018Aspirant
I have a similar problem, I purchased the R7000P back in January for my home. I also work from home and connect daily (wired) to my corporate VPN (SonicWall). Maybe 4-6 times a day, my VPN will drop, go to suspended, and then reconnect (process is about a minute, and is always the same). Initially I thought it was due to just the old laptop my company provided, but my system was refreshed this week and it still does it on the brand new system with Windows 10. My router appears to have the latest firmware, and I didn't make a lot of changes to the settings when I bought it so its not too far off from factory default. I was going to email into Netgear, but I didn't know that after 90 days you can't email for help without additional cost. For all I know, this may be a simple fix. Any ideas?
Thanks so much...
DaveHardware Version: R7000P
Firmware Version: V1.3.1.26_10.1.3
GUI Language Version: V1.3.1.26_2.1.38.1
