sijicl
Jul 15, 2017Aspirant
VPN connection drops every several minutes on my AC1750
Model version: R6700V2 Firmware:V 1.0.0.34 My VPN client is Cisco AnyConnect Secure Mobility Client on Mac, I need it to work remotely every day, but the VPN connection drops every several minutes, ...
- May 17, 2018
Upgrade to latest firmware yesterday, no drops since. I consider that "fixed" as often as the VPN would hang or drop. While I was in the Admin panels I also changed QoS for my work computer to Highest. I doubt that had any effect, I believe the firmware upgrade fixed the problem.
dpchristie
May 23, 2018Aspirant
I have a similar problem, I purchased the R7000P back in January for my home. I also work from home and connect daily (wired) to my corporate VPN (SonicWall). Maybe 4-6 times a day, my VPN will drop, go to suspended, and then reconnect (process is about a minute, and is always the same). Initially I thought it was due to just the old laptop my company provided, but my system was refreshed this week and it still does it on the brand new system with Windows 10. My router appears to have the latest firmware, and I didn't make a lot of changes to the settings when I bought it so its not too far off from factory default. I was going to email into Netgear, but I didn't know that after 90 days you can't email for help without additional cost. For all I know, this may be a simple fix. Any ideas?
Thanks so much...
Dave
Hardware Version: R7000P
Firmware Version: V1.3.1.26_10.1.3
GUI Language Version: V1.3.1.26_2.1.38.1
JamesGL
May 31, 2018NETGEAR Employee Retired
Hi dpchristie, dragonglazz,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
