maxmonz
Jan 23, 2022Aspirant
VPN connection from OpenVPN Android on R7000
I am no more able to connect to the VPN of my R7000 with the last OpenVPN app on Android. I think is a problem of compatibility but I don't know how to solve it.
Kitsap
Jan 24, 2022Master
On your Android device, the OpenVPN application keeps a log file. It may contain information on why the connection is not being made successfully.
How old is the profile configuration file on your Android device? If your router has had a recent firmware update you may have to update the configuration file on your Android device.
maxmonz
Jan 24, 2022Aspirant
I solved using the OpenVPN connect app on Android and it works perfectly.
The other one (OpenVPN for Android) can't connect.
