lightbulbstamps
Dec 07, 2016Aspirant
VPN controlling access
I have just got a R7000 router and i am wanting to use the openVPN on it. My main worry is security as it just seems to generate one set of files with no user name or password support for each user....
- Dec 08, 2016
Thanks ElaineM,
I am a lot happier at using the VPN now, that i can restrict a user from accessing my network throught the VPN unless their MAC address is set to allowed.
ElaineM
Dec 08, 2016NETGEAR Employee Retired
Welcome to the community, lightbulbstamps
It's true, there's no way to get Internet access if you have Access Control turned on unless you input the MAC Address of the computer/s under Allowed list.
- lightbulbstampsDec 08, 2016Aspirant
Thanks ElaineM,
- ElaineMDec 09, 2016NETGEAR Employee Retired
You're welcome.
Have a great day!
