readier-plebes
Jan 13, 2022Aspirant
VPN disconnecting every ~5 minutes
I've been having VPN disconnects with the R7000P. Built-in macOS 12.1 L2TP VPN client to Cisco Meraki VPN gateway. Running firmware version V1.3.3.142_10.1.75 on the R7000P. Was running V1.3.1 somet...
Jan 13, 2022Guru - Experienced User
readier-plebes
Sorry, misread what you were asking. The modem is a Motorola MB8600.
- FURRYe38Jan 13, 2022Guru - Experienced User
Ok,
Seems like if you have seen this problem with new FW and older FW, seems that this has gone on with out any resolution with NG. Something to contact them about or find you a better router option. The R7000 is getting to be a bit older now days. Probably other routers out there that will work for your needs.
