CTam's avatar
CTam
VPN For AC1900/R7000 open protocols for L2TP
Is there an option to enable AH and ESP protocol if I wanted to setup a local VPN on my computer? https://social.technet.microsoft.com/Forums/windowsserver/en-US/d05024ff-d6e7-49a8-8e73-132830dc7924...
  • JamesGL's avatar
    Nov 07, 2017
    Hi CTam,
    NETGEAR router is just a VPN passthrough. You may need to check with the software of the VPN that you are going to use for its configuration.
