Longwave
Nov 07, 2016Tutor
VPN For AC1900/R7000
New to this so bear with me.
I want to use VPN with this router. Instructions say there is a setting under the Advanced Tab. But nothing else.
Is this an actual VPN? Or, just an access...
- Jan 04, 2017
Actually what a person does depends on router use. How the router is configured in a buisiness environment with fixed devices will be a bit different than if it is in as personal/family environment with maybe a dozen mobile devices.
The router has a blocking function that I have found to be very effective. To only allow certain devices access I just blocked all. Then as a device attempts access and is blocked I unblock that device, if I choose. This is effective whether, or not a VPN is used.
My installation is mainly for about a dozen mobile devices. For travel they need a VPN anyway. To prevent any possible conflicts I decided not to install a VPN in the router. Instead each device has its' own that is efffective no matter where they go.
If I were using the router in a small business envoronment, or maybe for devices that didn't move I would put a VPN in the router.
All the VPNs I looked at had simple installations. None of the old fashioned tinkering. Just download, folloow the steps, and use.
No matter VPN or not the built in Access Control works just fine.
JamesGL
Nov 08, 2016NETGEAR Employee Retired
Hi Longwave,
Below is the KB article on how to configure the OpenVPN feature of the router.
JamesGL
Community Team
