Longwave
Nov 07, 2016Tutor
VPN For AC1900/R7000
New to this so bear with me.
I want to use VPN with this router. Instructions say there is a setting under the Advanced Tab. But nothing else.
Is this an actual VPN? Or, just an access...
- Jan 04, 2017
Actually what a person does depends on router use. How the router is configured in a buisiness environment with fixed devices will be a bit different than if it is in as personal/family environment with maybe a dozen mobile devices.
The router has a blocking function that I have found to be very effective. To only allow certain devices access I just blocked all. Then as a device attempts access and is blocked I unblock that device, if I choose. This is effective whether, or not a VPN is used.
My installation is mainly for about a dozen mobile devices. For travel they need a VPN anyway. To prevent any possible conflicts I decided not to install a VPN in the router. Instead each device has its' own that is efffective no matter where they go.
If I were using the router in a small business envoronment, or maybe for devices that didn't move I would put a VPN in the router.
All the VPNs I looked at had simple installations. None of the old fashioned tinkering. Just download, folloow the steps, and use.
No matter VPN or not the built in Access Control works just fine.
Longwave
Nov 15, 2016Tutor
Thanks for the information. It gave me an opportunity to consider althernatives.
As I understand it, if I were to activate the VPN function of the router I would mate the router with a separately purchased VPN package. Then, any devices using the router would by default use the VPN. The devices would only have VPN when using this router.
On the other hand I can install a VPN package on each device. That would let the VPN function follow the devices.
Based on that assumption I have installed individual VPN packages on each device and elected not to activate VPN on this router.
If I have it wrong feel free to, tactfuly, correct me.
JamesGL
Nov 16, 2016NETGEAR Employee Retired
Hi Longwave,
The VPN feature of the router works only for OpenVPN and will not work with other VPN package. The router provides the configuration and by using the OpenVPN software the connection triggers. If you have other VPN service, the router will not be able to use a server but could be a passthrough if you have ports opened of the VPN service.
JamesGL
Community Team
- gForce1Jan 04, 2017Aspirant
Does that mean that other devices using the router can access without OpenVPN installed on it? I would like only certain devices to use the VPN connection not all.
thanks in advance
- StephenBJan 04, 2017Guru - Experienced User
thanks in advance
You need to install the connection details (certificates, etc) on each device that uses OpenVPN. So this is under your control.
- gForce1Jan 06, 2017Aspirant
Ok got it, that makes sense it wil only use VPN if the cert files are in place . My question is do we have a procedure to get these on a Firestick or Fire TV ?
and will it still use the public IP? I don't see a way to actually set which IP it uses. it seems to put the DDNS entry in the cert file but won't people be able to see that and resolve that name?
- LongwaveJan 04, 2017Tutor
