Longwave
Nov 07, 2016Tutor
VPN For AC1900/R7000
New to this so bear with me.
I want to use VPN with this router. Instructions say there is a setting under the Advanced Tab. But nothing else.
Is this an actual VPN? Or, just an access...
- Jan 04, 2017
Actually what a person does depends on router use. How the router is configured in a buisiness environment with fixed devices will be a bit different than if it is in as personal/family environment with maybe a dozen mobile devices.
The router has a blocking function that I have found to be very effective. To only allow certain devices access I just blocked all. Then as a device attempts access and is blocked I unblock that device, if I choose. This is effective whether, or not a VPN is used.
My installation is mainly for about a dozen mobile devices. For travel they need a VPN anyway. To prevent any possible conflicts I decided not to install a VPN in the router. Instead each device has its' own that is efffective no matter where they go.
If I were using the router in a small business envoronment, or maybe for devices that didn't move I would put a VPN in the router.
All the VPNs I looked at had simple installations. None of the old fashioned tinkering. Just download, folloow the steps, and use.
No matter VPN or not the built in Access Control works just fine.
gForce1
Jan 04, 2017Aspirant
Does that mean that other devices using the router can access without OpenVPN installed on it? I would like only certain devices to use the VPN connection not all.
thanks in advance
Jan 04, 2017Guru - Experienced User
thanks in advance
You need to install the connection details (certificates, etc) on each device that uses OpenVPN. So this is under your control.
- gForce1Jan 06, 2017Aspirant
Ok got it, that makes sense it wil only use VPN if the cert files are in place . My question is do we have a procedure to get these on a Firestick or Fire TV ?
and will it still use the public IP? I don't see a way to actually set which IP it uses. it seems to put the DDNS entry in the cert file but won't people be able to see that and resolve that name?
- LongwaveJan 06, 2017Tutor
There are lots of VPNs out there. Each publishes it own specifications. Most take care of the nitty gritties, like certificates, automatically. Each also specifies the systems it will operate on. The old days of installing bits and pieces to make a VPN work are essentially gone for folks in this class of hardware.
This is not the place to talk about what will work on a specific system. You need Support from the individual VPN for that. Lots out there. So, just read, chat with their support, and make a decision.
- gForce1Jan 10, 2017Aspirant
Thanks I was only referring to using the VPN service builtin to this router and intergrating the OpenVPN with my device. I am assuming I just need to get the certs over to the device...
