Longwave
Nov 07, 2016Tutor
VPN For AC1900/R7000
New to this so bear with me.
I want to use VPN with this router. Instructions say there is a setting under the Advanced Tab. But nothing else.
Is this an actual VPN? Or, just an access...
- Jan 04, 2017
Actually what a person does depends on router use. How the router is configured in a buisiness environment with fixed devices will be a bit different than if it is in as personal/family environment with maybe a dozen mobile devices.
The router has a blocking function that I have found to be very effective. To only allow certain devices access I just blocked all. Then as a device attempts access and is blocked I unblock that device, if I choose. This is effective whether, or not a VPN is used.
My installation is mainly for about a dozen mobile devices. For travel they need a VPN anyway. To prevent any possible conflicts I decided not to install a VPN in the router. Instead each device has its' own that is efffective no matter where they go.
If I were using the router in a small business envoronment, or maybe for devices that didn't move I would put a VPN in the router.
All the VPNs I looked at had simple installations. None of the old fashioned tinkering. Just download, folloow the steps, and use.
No matter VPN or not the built in Access Control works just fine.
Longwave
Jan 06, 2017Tutor
There are lots of VPNs out there. Each publishes it own specifications. Most take care of the nitty gritties, like certificates, automatically. Each also specifies the systems it will operate on. The old days of installing bits and pieces to make a VPN work are essentially gone for folks in this class of hardware.
This is not the place to talk about what will work on a specific system. You need Support from the individual VPN for that. Lots out there. So, just read, chat with their support, and make a decision.
gForce1
Jan 10, 2017Aspirant
Thanks I was only referring to using the VPN service builtin to this router and intergrating the OpenVPN with my device. I am assuming I just need to get the certs over to the device...
- StephenBJan 10, 2017Guru - Experienced User
You download the appropriate file(s) from the openvpn page on the router.
Usually googling on the combination of openvpn and the device name will get you the specifics for the device.
