ksuwildkat
Dec 30, 2023Follower
VPN for R8000
Im looking to instal a router based VPN on the R8000. I dont want to have to use a client on each device, just a router based one. I can see how to do that with Open VPN. I tried NordVPN but they ...
Jan 02, 2024Guru - Experienced User
microchip8 is exactly correct. They're not supported on factory firmware.
If you're wanting a VPN, you'd have to flash it with aftermarket firmware. that voids your warranty and can brick your device.
But I've heard it works well
