ksuwildkat
Dec 30, 2023Follower
VPN for R8000
Im looking to instal a router based VPN on the R8000. I dont want to have to use a client on each device, just a router based one. I can see how to do that with Open VPN. I tried NordVPN but they ...
Kitsap
Jan 03, 2024Master
If you choose to flash your R8000 with third party firmware, prior to, be sure and save a copy of the OEM firmware and a copy of your current configuration file.
Should something go awry in the future, you will use these to return to the OEM configuration.
Minimal effort to establish a fall back position.
