AceAndrews's avatar
AceAndrews
Follower
Dec 31, 2020
VPN HELP! ax42000
Hello all!
I am having a really hard time setting up my VPN with my NightHawk AX4200. Im new to VPN and i need to use it on my router. Apparently Express VPN does not work on this model. Does anyone know what VPNs actually work on the model i have and how i can apply it to work? Im super new to all of this, so "how to do it for dummies" explaination would be appreciated. Really having a rough 5 hours with this. Any response would really really help.
thank you and happy new year!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    AX4200 isn't a Netgear model. Several devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    It looks like you have an Orbi system.  If so, you might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Orbi - NETGEAR Communities
    It can be easier to ask the VPN suppliers which devices they support. Sometimes they need customised firmware. That's not something that Netgear will be able to help with.
