Meccax
Jun 16, 2023Follower
VPN issues using ExpressVPN
My client bought an XR500 router with the idea that since a client connects to the network via WIFI automatically enters the VPN without the need to add this new device, it has been difficult for us to do this and the only solution we have is to do it manual thing that is difficult for us and I would like to know what we are failing for this to happen
We have followed this guide to the letter and still nothing https://kb.netgear.com/000060463/How-do-I-set-up-a-Hybrid-VPN-on-my-Nighthawk-Pro-Gaming- router
1 Reply
- KitsapMaster
Meccax wrote:My client bought an XR500 router with the idea that since a client connects to the network via WIFI automatically enters the VPN without the need to add this new device, it has been difficult for us to do this and the only solution we have is to do it manual thing that is difficult for us and I would like to know what we are failing for this to happen
You might get a better response if you posted in the community dedicated to Nighthawk Pro Gaming routers.
A moderator will most likely move your post.
