pharbrian's avatar
Jul 30, 2018
VPN not working after the latest firmware update
With the latest firmware update, version 1.0.9.34_10.2.36, the VPN option using openVPN is no longer working. It will show from my android that my VPN is connected to my VPN on my router, but it will...
  • gandmclark's avatar
    gandmclark
    Jul 31, 2018
    I also can't get VPN working on 1.0.9.34. OpenVPN on Windows, Android and Tomato connects but no comms happens. Nothing out of the ordinary appears in the OpenVPN logs nor the Netgear logs.
    I was previously on 1.0.9.32, which worked OK and which uses the same certificates as 1.0.9.34.  ( 1.0.9.32
    was the firmware that changed MD5 to SHA256) I've done a file comparrision of all the certificates downloaded from the router from 1.0.9.32 and 1.0.9.34 and they are identical. So reloading the certs in OpenVPN would make no difference.
    I have now reverted to 1.0.9.32 and VPN now works again.
