TXTornados's avatar
Oct 30, 2017
VPN on R7800
Like the other thread, I want to use my router as the VPN client, I do not want to have it loaded on the individual devices (IOS, Android, MAC and Win).  Reviewing the discussion, I was going to try ...
  • avtella's avatar
    avtella
    Oct 31, 2017
    Yes a tftp flash from command prompt is all that’s needed to revert to stock, in fact stock firmware settings are still saved when you revert.
