Yargile
Nov 21, 2022Aspirant
VPN requiring frequent reboots
Nighthawk R8000P FW: V1.4.4.94_1.3.56 All of the sudden I have all users having trouble with OpenVPN to the Netgear. The router is requiring reboots almost daily for clients to be able to connect. ...
Nov 21, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try enabling IPv6 (AUTO) on the router.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- YargileNov 21, 2022Aspirant
Thanks for your response:
- Technicolor DPC3941B modem
- I will turn on IPv6 auto this evening
- Just replaced the network cable per your suggestion
- Device has been fully power cycled (unplugged for minutes), this was done prior to this support post
- Factory reset has not been performed, wanted to rule out everything else first
Can you tell my why you think the wireless configurations may have any impact on remote clients VPNing into this device? I would like to understand for future. If you are asking about the remote client connectivity on their local networks, it is a mixed bag of wireless (with a variety of settings) and wired. If you are asking about the wireless on the main network with the Netgear in question, 2.4GHz is on Auto and 5GHz is on 44. There are other networks nearby, a handful, and are not on conflicting channels. Our internal wireless works well.
- FURRYe38Nov 21, 2022Guru - Experienced User
Checking for any possible interference issue on wireless. If your wireless is working ok, then thats fine.
Lets see if enabling IPv6 helps...
