Polymorphic
May 14, 2019Aspirant
VPN service - apply button does not work Netgear X4S R7800
Firmware version: 1.0.2.62 When i go to: Advanced->Advanced Setup->VPN Service and click 'Enable VPN Service' and then click apply, i get a warning about DNS/Static IP. However the setting is not s...
- May 16, 2019
Found the solution
If DDNS isnt enabled, the settings isnt saved.
It would be nice if the page gave that information.
This also kind of sucks when your ISP is assigning my static IP with DHCP.
Polymorphic
BTW - tried to reset to factory default, but there is no change.
