nodaicrag's avatar
nodaicrag
VPN setup and shows connected, but on log file says backtrack occurred
Hi, I setup a VPN from a home in the USA on my R6900 router. (I setup a different one from the USA and that works). Installed the Open VPN, downloaded the client certificate from the router, used noi...
  • nodaicrag's avatar
    Jun 21, 2017
    Spoke with Netgear tech support and issue is resolved. I am now able to to connect to my VPN and stream Netflix. Under the section of VPN, after selecting the radial button for "All sites on the internet and home network," I was able to connect.
    For those wanting to connect to their Netgear VPN, learn from my trial and errors:
    1) Under setup > Lan Setup = make sure you change the value of the 192.168. X .1
    2) Advanced Setup > VPN setup > Clients will use this VPN to access All sites on the internet and home network
    3) Download client (I am using Windows 10) and connect with Open VPN
