JacquieMz's avatar
JacquieMz
VPN to access remote LAN without using Remote Desktop
I am looking to add mobile access to my LAN network thru WIFI.  I already can access thru remote desktop to computers running Win 7 Pro, but I need to be able to remotely access the "server" as if th...
  • JamesGL's avatar
    JamesGL
    Jan 18, 2017
    Hi JacquieMz,
    The scenario you wanted may not be supported by the OpenVPN feature of the router. You may need to follow the suggestion of your software provider.
