JEKul
Sep 14, 2021Initiate
W3000rpv3 connectivity
Hello. I'm very new to WIFI. I'm looking at a wn3000rpv3. Q1- how old is it? Q2- I have two items - a smart lock and a Ring door camera. They have separate apps. Can they both be hooked up to this W...
Sep 14, 2021Guru - Experienced User
That version was released in 2015. The original was released in 2013.
Its a pretty base model N300 extender.
Both of those devices should work with the extender but it isn't the highest performing extender.
JEKul
Wow thanks for such a speedy reply. That's what I wanted to know- not ehat I wanted to hear!
- plemansSep 14, 2021Guru - Experienced User
for roughly the same prices on amazon, the ex6150 is used/refurbed as the new wn3000rp and is much higher performing. Plus it has mesh. Might be worth taking a look at
