basic
Jan 31, 2022Aspirant
Waiting for server response when setting up VPN with Orbi on MacOS
I'm trying to connect to a VPN for work through my Orbi. I've followed the OpenVPN instructions using Tunnelbrick. When I do that I am never able to successfully connect to a server. It shows me this screen:
The only errors that I'm seeing in the logs are:
2022-01-31 16:01:47.983220 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 2022-01-31 16:01:47.983270 TLS Error: TLS handshake failed
Is there some other setting on the Orbi that I can change to get this VPN working?
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
1 Reply
Thank you.
