rpee47
Oct 02, 2021Follower
Wall mount Nighthawk CM 2000
Has anyone tried to wall mount a Nighthawk 2000 CM cable modem? There's no Netgear solution, and the flared base makes the product to wide to fit traditional cable modem wall attachments.
1 Reply
I haven't seen any wall mount options and I doubt you will. The CM2000 needs good airflow (heat is the death of electronics) and wall mounting it is going to block a whole side of airflow.
