NoWire's avatar
NoWire
Guide
Feb 16, 2016
Wall mounted R8000
Hi,   How should the antennas be positioned for best signal when I hang my X6 on the wall?   Best Regards, Kristian
  • NoWire's avatar
    NoWire
    Feb 20, 2016
    Okay, received my X6 yesterday and installed it.
    My first thought was, if it's as good as it is big, then it has to be good, and it is (IMHO)  :-)
    After some testing I have found out that the location in the house is not critical, it works excellent in all corners!
    In a couple of days we will have fiber installed in the house and then perhaps, to get the best of it, location is more critical.
    I'll have to test!
    Today we have 30/4GB, and for the devicecs that can handle the speed (802.11n) it's no problem, but tomorrow it will be 100/50GB (or 500/100GB have not decided yet)...!
    Have a nice day!
