NoWire
Feb 16, 2016Guide
Wall mounted R8000
Hi, How should the antennas be positioned for best signal when I hang my X6 on the wall? Best Regards, Kristian
- Feb 20, 2016
Okay, received my X6 yesterday and installed it.
My first thought was, if it's as good as it is big, then it has to be good, and it is (IMHO) :-)
After some testing I have found out that the location in the house is not critical, it works excellent in all corners!
In a couple of days we will have fiber installed in the house and then perhaps, to get the best of it, location is more critical.
I'll have to test!
Today we have 30/4GB, and for the devicecs that can handle the speed (802.11n) it's no problem, but tomorrow it will be 100/50GB (or 500/100GB have not decided yet)...!Have a nice day!
NoWire
Feb 18, 2016Guide
Noted!
NoWire
Feb 20, 2016Guide
I'll have to test!
Have a nice day!
- carll76Feb 22, 2016Apprentice
how are you finding it ? I can only dream of an interent connection like you have.. The best I can get is 80/20 FTTC it would cost me thounds £ to get FTTP.. Unless google come to Leicester in the UK :)
