OldBob's avatar
OldBob
Luminary
Mar 28, 2020
warrantee process for replacement of a Nighthawk router
After hours with support it seems the firmware update will not update on my new 88 days old Nighthawk router.  They want me to pay big bucks to extend the phone coverage which I said seems unfair/une...
  • michaelkenward's avatar
    Mar 29, 2020
    OldBob wrote:
    After hours with support it seems the firmware update will not update on my new 88 days old Nighthawk router.  They want me to pay big bucks to extend the phone coverage which I said seems unfair/unethical to want me to pay for support from a company that cannot fix my issue in the first place.
    How did you contact support?
    The bit about being asked to pay for support may be a scam.
    If you called a number that you found with a web search, that almost certainly had nothing to do with Netgear.
    Netgear itself does not provide paid for support. It does that through GearHead Technical Support.
    GearHead Support
    Web searches can deliver results that scream "Netgear support" at the top but that turn out to be anything but. Using them can be dangerous, for your network and your bank balance.
    If you login to mynetgear, can you see your router there?
    MyNETGEAR | Login
    If so, that is where to ask for support. If that is what you did, then the warranty process is different.
    OldBob wrote:
    Is this really the procedure for replacing a unit 88 days old?
    No. Start the RMA process by checking MyNetgear.
    How do I request a Return Material Authorization (RMA)? | Answer | NETGEAR Support
    Warranties are at least a year.
