visualsoul
Dec 05, 2020Follower
Warzone -- Port Forwarding for Multiple Devices
We are trying to forward ports for both our PC and PS4 to be able to play COD: Warzone. Right now, I'm only able to forward ports for the PS4 and we are able to get an open NAT, but I'm stuck on Stri...
antinode
Dec 05, 2020Guru
> We are trying to forward ports for both our PC and PS4 [...]
_How_, exactly? Which ports? To where?
> [...] I'm only able to forward ports for the PS4 and we are able to
> get an open NAT, but I'm stuck on Strict for the PC. [...]
"not able" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
If you're trying to forward some particular set of ports to multiple
destinations, then I'd guess that you're doomed, because that makes no
sense.
> [...] Seems like there should be a solution available.
Seems as if there should be a better problem description, too.
- aaronibm21Apr 08, 2021Luminary
Buenas tardes, podrias decirnos que puertos y como lo has echo para configurar el xr500 los puertos del warzone??
Gracias!!
