j3trooper
May 13, 2021Guide
Weak Security
I am getting a message informing me of weak security (WPA) "If this is your Wi-Fi network, configure the router to use WPA2/WPA3 Personal (AES) security type for this network" In Netgear Genie my w...
- May 15, 2021
Use WPA2-PSK [AES] only
j3trooper
May 14, 2021Guide
Thanks for your reply.
Not the browser. It is shown on my iMac desktop in the top right hand corner when I click on the Wi-Fi icon.
It also displays on my Windows 10 laptop.
michaelkenward
May 14, 2021Guru - Experienced User
Down to your operating system then.
It is up to you which you believe, that or your router.
This is where to read about Netgear's security:
Security Advisory | About Us | NETGEAR
- antinodeMay 14, 2021Guru
> In Netgear Genie my wireless network is listed with the Security
> enabled (WPA2-PSK)
> and the same on my 5G network.Has your router a model number? Look for "Model" on the product
label. Firmware version?> My router has the latest firmware.
As always, an actual version number would be more useful than your
opinion of what's "latest" today.What are the actual security options available? Exact text --
copy+paste is your friend. Which one(s) did you choose?Note: "WPA-PSK [TKIP] + WPA2-PSK [AES]" is not "WPA2-PSK".
> Should I be concerned or should I just ignore the message?
Assuming that the message is accurate, and you are allowing
(plain-old) WPA, not only WPA2, then there's a reason for that warning.WPA is less secure than WPA2 (or WPA3).
> Down to your operating system then.Both of it. I know nothing, but I'd guess that macOS (unknown
version) and Windows 10 (unknown version) would not both be wrong about
this. But what do I know?- j3trooperMay 15, 2021Guide
Model is Nighthawk X4S D7800
Firmware Version V1.0.1.60
Security Options None WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES] WPA/WPA2 Enterprise Bold is selected for both 2.4GHz & 5GHz
Wireless Network (2.4GHz b/g/n) Enable SSID Broadcast Enable 20/40 MHz Coexistence Both are enabled
Mac OS Big sur 11.3.1
- microchip8May 15, 2021Master
