j3trooper
May 13, 2021Guide
Weak Security
I am getting a message informing me of weak security (WPA) "If this is your Wi-Fi network, configure the router to use WPA2/WPA3 Personal (AES) security type for this network" In Netgear Genie my w...
- May 15, 2021
Use WPA2-PSK [AES] only
j3trooper
May 15, 2021Guide
Model is Nighthawk X4S D7800
Firmware Version V1.0.1.60
| Security Options | |
| None | |
| WPA2-PSK [AES] | |
| WPA-PSK [TKIP] + WPA2-PSK [AES] | |
| WPA/WPA2 Enterprise |
Bold is selected for both 2.4GHz & 5GHz
| Wireless Network (2.4GHz b/g/n) |
| Enable SSID Broadcast |
| Enable 20/40 MHz Coexistence |
Both are enabled
Mac OS Big sur 11.3.1
microchip8
May 15, 2021Master
- j3trooperMay 15, 2021Guide
Thanks for all the replies.
I did look at changing the setting to that previously but got the message that it could slow down the data transmission. Have now changed to that setting and hoping that the message was just a generic message.
Thanks
Pev
- cfNetMay 18, 2021Initiate
Fun Fact:
IF you use an Insight Managed device, it is impossible to have WPA2 Enterprise with AES because the Insight interface does not support configuring that setting. In this case, you would have to unmanage the router, and set the AES in the local router interface. IF you ever manage that router with Insight again, it will overwrite your AES with Mixed Mode/TKIP.
