st000001
Feb 24, 2023Tutor
WEB interface labels blank?
Has anyone seen this? Tried Opera, FF and Edge, same results.
- Feb 24, 2023
A 'normal' restart did not work. However leaving the power adapter unplugged w/ the power switch on for a minute did work and now the interface labels are back.
st000001
Feb 24, 2023Tutor
Feb 26, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
