Steve_in_TN
Jan 31, 2022Aspirant
Web pages unavailable - but ok after 3 or 4 browser refresh
A few months ago, started having troubles accesing web pages, getting the Web Page Unavailable error, but the pages most of the time will come up after refreshing the browser 3 or 4 times. Happens o...
Jan 31, 2022Guru - Experienced User
If you're on the newer version, make sure IPv6 is enabled.
I've seen that resolve it for some.
Steve_in_TN
Thank y'all for prompt replies.
Regarding the IPv6 setting, I checked and mine was in fact disabled. I certainly can and probably will try with it enabled to see if that does make the current FW work; however, the web pages are readily accesssible with IPv6 turned off, and using the older router firmware.
- plemansJan 31, 2022Guru - Experienced User
Not sure why it makes a difference but a lot of people have had good results with IPv6 enabled.
