nUUK25
Aug 20, 2019Tutor
Web Publishing Service on Zuxel NAS326 and Port Forwarding on Netgear Router
Hello, I am on uncharted waters - I only know how to setup wireless: set password, naming the flag and enable encryption. I have no experince in Port Forwarding and what it does. According to Zyx...
- Sep 06, 2019
Hello Antinode,
I just want to thank you for all your help - It has been most pleasant and a great leaner for me.
Best regards Lars
antinode
Aug 20, 2019Guru
> [...] I have no experince in Port Forwarding and what it does. [...]
That will need to change. Port forwarding is what the router does to
deal with a message which arrives at its WAN/Internet port from the
outside world. Your ISP has assigned one (external) IP address to your
whole installation; either you or your router has assigned an entirely
different (LAN) IP address to each device on your LAN.
If someone in the outside world wants to send a message to a device
on your LAN, all he can do is send it to your router. How, then, does
the router know what to do with that message? To which of your devices
(if any) should it forward that message?
A port-forwarding rule is what tells the router what to do with such
a message.
> [...] http://[server-name:5000]/MyWeb/Public [...]
More precisely:
http://[server-name]:5000/MyWeb/Public [...]
Note that your "[server-name]" could also be your external IP
address instead of a DNS name.
That "5000" is the relevant port number. You can think of it as like
an apartment number after a street address (IP address). In this case,
you'd want a port-forwarding rule like:
Service Type: TCP+UDP
External port range: 5000
Internal port range: 5000
Server IP Address: <LAN_IP_address_of_NAS>
That implies that the NAS device needs a fixed LAN IP address, which can
be arranged at ADVANCED > Setup LAN Setup : Address Reservation.
With such a rule in effect, when a message destined for port 5000
arrives at your router's WAN/Internet port, the router will forward it
to the device at <LAN_IP_address_of_NAS>. When that device sends a
reply to that message, the router will handle the reply, ensuring that
it returns to the outside-world device which sent the original message.
It's important that the IP address of the WAN/Internet on your router
match your public (external) IP address. If there's another router
between yours and the Internet (which could be a second router at your
site, or at your ISP's site) then you can expect problems.
As you might guess, you could specify different external and internal
port numbers in your port-forwarding rule. The external port number is
what is used in the outside world; the internal port number is what is
used on your LAN. So, for example, if you had a second NAS device, you
could create a rule like:
External port range: 5001
Server IP Address: <LAN_IP_address_of_NAS-2>
Then, a URL like the following would reach "NAS-2":
http://[server-name]:5001/MyWeb/Public [...]
On your LAN, NAS-2 would still use port 5000, but, because of that
port-forwarding rule, it would be seen at port 5001 from the outside
world.
nUUK25
Aug 21, 2019Tutor
Hello, ...and thanks for the answer; Antinode, which open up some core issues:
You mention that the IP which my router receives from my ISP should be static and I have a suspision that is not the case !! In general, I check ip with IPCONFIG in CMD. If I unplug the router and plug in a PC on the wall it gets nearly the same ip (except for one digit) as what the router gets. Similarly another PC get another ip, 2 digits away from the router ip which tells me they are all assigned dynamically. The final straw is; if I try to ping the router IP address from a PC which connects to the internet over the mobilenetwork; USB-modem, it states; 'reply from 10.117.15.173: Distination net unreachable' ......Which I interpret; the router do not get a real external IP addresse and it matches the fact that my ISP advertise on their website that I can buy a fixed IP address for a minor one time payment.
Antinode, am I on the right path, you think ?
- schumakuAug 21, 2019Guru - Experienced User
nUUK25 wrote:...if I try to ping the router IP address from a PC which connects to the internet over the mobilenetwork; USB-modem, it states; 'reply from 10.117.15.173: Distination net unreachable' ......Which I interpret; the router do not get a real external IP addresse ...
If your R7800 does show the same RFC1918 address on the Advanced -> Internet port IP address information, this is correct.
- nUUK25Aug 21, 2019Tutor
Yes, the address is 10.168.50.157 in the router > Basic > Internet > Interet setup > internet ip address. I get 10.168.50.156 to a pc connected to the wall plug and another pc gets ip: 10.168.50.158
If I ping 10.168.50.157 from a usb-modem connected PC i get the message: 'reply from 10.117.15.173: Distination net unreachable'
An externet real static public ip for the router should be pingable I suppose !
So I should buy myself a static ip address from my ISP ?
- antinodeAug 21, 2019Guru
> [...] 10.117.15.173 [...]
"10.a.b.c" is a non-routable, private address.
https://whois.arin.net/rest/net/NET-10-0-0-0-1/pft?s=10.117.15.173
> [...] my ISP advertise on their website that I can buy a fixed IP
> address for a minor one time payment.If you want to run a server which can be reached from the outside
world, then a public IP address would be helpful. A fixed, public IP
address would be even more helpful.> An externet real static public ip for the router should be pingable I
> suppose !Yup. But see: ADVANCED > Setup > WAN Setup > Respond to Ping on
Internet Port.> So I should buy myself a static ip address from my ISP ?
Sounds right to me.
