technologidiot's avatar
Mar 15, 2022
Webpages fail to load / specific game disconnects all the time.
Get this error a lot when browsing the web
This site can’t be reached
Check if there is a typo in *********.
If spelling is correct, try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
Get disconnected from a game a ton, and keep getting server authentication failure, never had this error before. but I just moved and everything else is connected fine.
I've flushed DNS, Cleared Cache, disabled and re-enabled firewalls for the game and there are no firmware updates for my router.
I don't have a slow connection so I don't know whats happening.
