nikony13's avatar
nikony13
Weird problem with Walmart.com
hello
i have a very strange problem when I am connected to Internet via R8500 router. I cannot navigate Walmart.com website. I can open it but it doesn't matter where I click nothing happens. I tested all my devices connected to the same network (iPhone, iPad, Windows laptop, Windows desktop) same problem. But as soon as I turn off wifi and use cellular data the website works or if I connect to a different network it works. I know it's a very strange problem, and only with Walmart website but I tried anything ( reset the router., reboot the modem and the router ) still doesn't work
also I tested via vpn and it works
any advice?
Thank you
  • Retired_Member's avatar
    Retired_Member
    Jul 12, 2016
    select use PC MAC in setup...internet setup   reboot modem and router
1 Reply
    Retired_Member
