Ice21's avatar
Ice21
Follower
Dec 10, 2020
What’s the difference between AX6600 and AX6200
Bestbuy has a AX6600 and Costco has a AX6200. I look at both data sheets and they are bsacically the same product as if costco has its own edition of the AX6600. The only differences i saw with between the two is that the 6600 is millimeters larger than 6200 and that doesn't even mean anything to me and that the 6600 costs $50 more than the 6200. Could someone clarify?
  • Basically comes down to this:
    best buy= RAX70-has 600mbps 2.4ghz 1.2gbps 5ghz and 4.8gbps 5ghz
    Costco=RAX78- has 460mbps 2.4ghz, one of the 5ghz bands is only 960mbps instead of the 1.2gbps in the rax70, the other is 4.8gbps
1 Reply
  • plemans's avatar
