OhBeWan
Aug 02, 2022Guide
What 3rd party firmware are we using these days for the R7800?
I have posted before about issues with Netgear firmware updates. My other posts list those issue in detail. https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Requests-for-firmware-changes-on-R...
michaelkenward
Aug 03, 2022Guru - Experienced User
OhBeWan wrote:
Had hoped that a future updated firmware would fix things.
Forgive me if I don't dive through past conversations, but what things still need fixing?
My R7800 soldiers on with little, if any, sign of issues.
Perhaps I am not doing the sort of things that bug you.
- OhBeWanAug 03, 2022Guide
There are 5 issues listed: 3 have to do with the way attached devices are dealt with. 1 deals with the router's inability to find the internet after reboot. 1 deals with randomly dropping wireless clients.
I am a home user that has 30 devices or more connected. About half are wireless. I have to do port forwarding and static IP's within the network so identifying what is on the network is important to me. If you have fewer devices and not very many are wireless, then maybe you would not have noticed these issues.
- michaelkenwardAug 03, 2022Guru - Experienced User
You don't say here what you mean by "the way attached devices are dealt with" but this is a constant refrain with many Netgear routers. They are hopeless at keeping track of what's connected. But it seems to depend on how you are checking that. Apps on mobiles are far worse than the browser graphical user interface (GUI) or, my preferred option, the desktop genie and its "map".
As to reconnecting, no problems here – again you don't describe the issue– but I did find that it depends on the modem in front of the router. Some modems are so slow to connect that the router threw in the towel and timed out. That one went away when I changed the DSL modem/router (D6400 in bridge mode) for a DM200.
Wireless is also not an issue here.
I provided a link to the detailed explanation at your request, but OK, here is the detail:
"1) Change the user interface. Now you logon to the router. At the home screen, you click on "Attached Devices". It then shows 2 devices per screen. I would like a list view or more space on the screen devoted to devices. And show the Mac ID. Yes, you can get a list view by (from the Home Page) clicking the "Advanced Tab", then "Security", then "Access control." Problem with the original view is that it does not show the Mac ID. You must click the device. This makes it hard to solve problems when you only have the Mac ID of the offending device.
2) Identifying devices on your network is key. At the home screen, you click on "Attached Devices". Click on a device, change the name, change the Device Type and click Apply when done. Later, I go back in and many, but not all of the time, that device is now "unknown" for name and type. Only way I have found to, for sure, make it remember the device is to click the "Advanced" tab, then "Security", then "Access Control". Then turn on Access Control but allow new devices to connect. Once I have done this, I can name the device and name the device type in this screen. My request here is to make it easier to save and stay saved from the "Attached Devices" screen.
3) I find the device type to be very useful. I wish this were expanded. At a minimum, I would like you to add Roku, Amazon Echo and Thermostat as types. I understand that you couldn't possibly anticipate all devices that everyone could have but how difficult would it be to expand that list by 20 more types? Can I sort network devices by type so I can see info on that specific type?"
I use the a PC to look up devices so I am going through my browser. Yes, I can drill down and look up items and go through a procedure to save names of devices and yes, I don't absolutely have to have device type expanded, but come on, Cheaper routers have some of these features. Who wouldn't want the ability to easily name a device? Who wouldn't want the MAc ID on the main screen? Who wouldn't want to see more than two devices at a time?
Not trying to be sarcastic. Just saying that a power user like yourself not having any issues, is not a good litmus test.
