mc510
Aug 04, 2019Guide
What does "Access Control" do? Netgear provides contradictory information
Netgear online help says: "Use the access control feature to block devices from connecting to your router’s Internet connection. Note: Blocking devices with access control only blocks them from acce...
- Aug 04, 2019
The second one. It blocks devices trying to connect to the router (they don't get IPs and other information such as DNS)
microchip8
Aug 05, 2019Master
It might get an IP (I haven't used Access Control in ages) but as the doc says, it won't be able to communicate with other devices nor access the Internet
mc510
Aug 06, 2019Guide
microchip8 wrote:It might get an IP (I haven't used Access Control in ages) but as the doc says, it won't be able to communicate with other devices nor access the Internet
I guess so, but it would make more sense the way you described it; the only use for this Access Control function is totally ban a device from the network, right? There's no possible reason that you'd want to allow a device to get an IP address from the router but not be able to communicate on either the LAN or the WAN. I mean, an IP address is utterly useless except for communication with other devices, which Access Control prohibits, so ....
